40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to infill a topo hole from plit surface
Fri, Jun 15, 2012 at 9:52:32 AM | How to infill a topo hole from plit surface
JRPcad
I have revisited a model I worked on a while back where a client has decided they wanted to remove a ramp. I originally decided to split the surface to cut away the topo so that it didn't make te ramp look dodgy (where as if i had done it now I would have used a pad instead of splitting) I deleted the split element which obviously left a hole in my topo. Is there a way to infill this hole, e.g. put some topo back there so there is no hole. I tried inserting points into it thinking that would be the obvious way but Revit said no.
Anyone know how I can infill this this topo hole without having to remake the topo from scratch?
For Architectural Services visit www.jrpcad.co.uk
Fri, Jun 15, 2012 at 9:54:55 AM | How to infill a topo hole from plit surface
JRPcad
Lol I just found the solution as soon as I posted,
All I had to do was delete the points that created the boundary for the hole, I ddn't think this would work as I couldn't selected the edges of the hole, But all good now Winking
Hole in my topo surface
Thu, Nov 8, 2012 at 8:36:27 AM
11
VOIDING TOPO FOR FNDN HOLE??
Wed, Jun 7, 2006 at 3:26:49 AM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:59 PM
Hole in surface
Wed, Nov 14, 2018 at 12:15:28 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:11 PM
Page generation time: 1.1499
