33 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> adding views to a sheet from another file...
Tue, Jan 3, 2006 at 2:00:10 AM | adding views to a sheet from another file...
mmetin
mmetin Avatar
how can i combine the drawings done in 2 projects to a single sheet? i'm a new user and heard about worksets but i think this is a common printing issue and could be solved without using worksets..thank you
Tue, Jan 3, 2006 at 10:40:05 AM | RE: adding views to a sheet from another file...
Rythmick
5 Stars: 2 Votes
You can use the import/link tool to bring one project into another or you can cut and paste from one to another. If you want just 2d drawings without the models combined, try exporting the views you want to document to 2d dwf, pdf, or dwg then import those onto a drafting view. Drafting views are non model related.
Adding views to a sheet - get all the clip rejoins the same?
Thu, Dec 20, 2007 at 8:35:44 PM
adding views to sheet
Mon, Jun 30, 2014 at 3:13:30 PM
Model file vs. Sheet file
Sun, Nov 9, 2014 at 4:54:46 PM
Sheet Underlay
Fri, Sep 12, 2014 at 2:13:26 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:29 PM
Page generation time: 1.5692
