130 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Help of Hatch Tile in a Ceramic Material
Wed, Jun 13, 2012 at 3:18:47 AM | Help of Hatch Tile in a Ceramic Material
Extrude72
Hi all,
sorry for the stupid question, but I have a problem:
I would like to use the same material for vertical finish (for interior wall layer) and horizontal finish (for top floor layer), the material have the Hatch Pattern of double square lines for surface (6in).
The problem is that in a 3D view I can see only in the wall finishing the above mentioned hatch and nothing in the floor finish.In Plan view is visible also in the floor and I can't understand the reason why....Could plese help me in order to see in the 3D view in both surfaces the same hatch?Many thanks in advance
Wed, Jun 13, 2012 at 6:33:29 AM | Help of Hatch Tile in a Ceramic Material
In 3D views, you vision angle is too accute to the floor.  Revit will not show patterns at accute angles.
Wed, Jun 13, 2012 at 8:39:56 AM | Help of Hatch Tile in a Ceramic Material
Extrude72
Many thanks for the clarification,
I also discovered to changed the visibility and Grafically of 3D view lines (erroneously) and when I removed this kind of modification the hatch appear correctly
Best Regards
Fri, Aug 31, 2018 at 10:15:19 AM | Help of Hatch Tile in a Ceramic Material
1bchristian
I have this same problem but placeing 12"X24"X2" marble cubes and would like to vertical seems to show on the 2" thickness. But my problem is I didn't understand what you are saying.
Partial height Ceramic Tile
Thu, Feb 23, 2012 at 9:31:28 AM
Ceramic Tile Flooring
Wed, Jan 2, 2008 at 9:03:02 AM
Custom hatch of odd tile size
Fri, Jul 20, 2012 at 5:27:57 PM
Material takeoff
Sun, Feb 13, 2011 at 6:38:47 AM
Can Door/Window cut through multiple walls
Wed, May 26, 2010 at 10:06:37 AM
Page generation time: 1.2986
