54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> doors in storefront
Mon, Jun 11, 2012 at 10:04:48 AM | doors in storefront
beccabecca11
I'm trying to add a glass door to a storefront system (Revit 2013) and when I try to load the "single glass" family I get an error that Revit cannot load that Family.  This is how I have changed curtainwall or storefront panels in previous versions of Revit, is there a different way to do it in 2013?  How am I supposed to load these families into my model?
Mon, Jun 11, 2012 at 10:12:47 AM | doors in storefront
Revit still works the same way except it does limit family loading to appropriate views.  Simply change to an elevation view of your storefront, be in the view, then load your family.
Mon, Jun 11, 2012 at 10:19:17 AM | doors in storefront
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Not sure how you did it in the past.
Here's how I would approach putting a glass door into a curtain store front.
Start by using the 'Load Family' tool and load the door(s) 'Curtain Wall Sgl Glass.rfa' or Curtain Wall Dbl Glass.rfa from the Door folder.
In the modeling window click (and tab) to select the existing Curtain Panel (to be replaced).
Un-pin it by picking the blue Pin.
Select the panel again and using the Type Selector change it to one of the above Door Types.
You cannot just place a door into a store front, you have to swap out the panel for one of the special door types listed above.
You also have to make sure the curtain grids and mullions are in the correct position because the inserted door will simply fill the panel space.
Hope that helps.
Mon, Jun 11, 2012 at 10:24:33 AM | doors in storefront
beccabecca11
dgcad - that is precisely how I have added doors and am trying to do it now... The problem is that when I select a glass pane, the only options I have are "glass" or "solid" panels.  I need to load in the glass door family so that it shows up as an option.
wwhub - I have tried to load the family in a floor plan view, elevation, 3d view, section... every time I get the same error:
"some or all of the family files you selected cannot be loaded.  you must choose family files of the category compontent.  Do you want to retry loading a new set of files?"
this is a standard family, not one I have created or edited.
Mon, Jun 11, 2012 at 10:38:58 AM | doors in storefront
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Interesting . . . . . I don't have 2013 in front of me. Just 2012, 2011.
If you go straight to the 'Load Family' tool off the Insert Tab (not from any other command or from the type selector or dialog box) it usuually doens't qualify the 'Category'. You are loading a family. It could be a detail component, door, window, curtain wall, profile  . . . . . . .
It's different if pick 'load family' from within a command sequence or dialog box.
Try this: Start REVIT and do nothing except pick the 'Load Family' tool off the 'Insert' tab. REVIT should not question the category ?? How would it know what category you intend to insert ? You should be able to insert any category.
Mon, Jun 11, 2012 at 11:05:14 AM | doors in storefront
This is simply stupid!!!!  Probably some of those programmers that came over from AutoCAD.
Goto the door tab, then pick load family.  S T U P I D !!!!  Not you - AUTODESK.
Mon, Jun 11, 2012 at 11:09:43 AM | doors in storefront
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
We already witnessed (and mourned) the loss of the original REVIT programmers. That was evident a few releases ago. Now we're getting stuck with the AutoCAD Architecture programming failures . . . . DOH !
Mon, Jun 11, 2012 at 11:13:37 AM | doors in storefront
beccabecca11
GENIUS!  (You, WWHub, not autodesk!)
and this explains some of the other problems with loading furniture etc that I'm having.  I'll have to play around with that stuff too and re-learn some new habits.  what a crock!
thanks for your help
Tue, Oct 22, 2013 at 6:20:55 AM | doors in storefront
ArchStudentWIT
3 Stars: 2 Votes
Here is a tutorial:https://www.youtube.com/watch?v=xjR9VXWOCuw
Tue, Oct 22, 2013 at 7:30:19 AM | doors in storefront
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Arch you post a lot of tutorials you find in old threads.  It is much better if you put them in the tips and tricks section under a new thread with a corresponding subject title.
Tue, Oct 22, 2013 at 8:25:25 AM | doors in storefront
#11
ArchStudentWIT
3 Stars: 2 Votes
Sorry, I am not good with these forums. I simply google my problems and these are the threads that come up. I don't pay much attention to the dates. I then find the links on youtube, and post them here for others after me to follow. If you can send me a link to where you are suggesting that I post, I'll happily post there instead.
Thanks!
Storefront Doors
Sat, Jun 11, 2011 at 8:49:02 AM
Arched storefront doors...?
Wed, Mar 16, 2011 at 12:38:56 PM
Storefront Wall needs Storefront Doors
Mon, Dec 3, 2007 at 8:58:53 AM
Storefront Doors in Door Schedule
Wed, Sep 9, 2009 at 4:32:18 PM
Storefront Doors
Mon, Nov 29, 2010 at 5:39:02 PM
Page generation time: 0.3190
