Forums >> Revit Building >> Technical Support >> Settings for spot coordinates - Revit 2012
Fri, Jun 8, 2012 at 10:26:36 AM | Settings for spot coordinates - Revit 2012
rat69
Hi,
I have a big flat floor (pool deck) and I have to locate several points (floor drains, corners of elements, posts, etc). I already located all my points using the "Spot Coordinate" option. My deck is a perfect circle and we want the center of the circle to be 0.00, 0.00 (I am using shared coordinates). The problem is that we need the tags to show N,S,W & E directions, instead of only N or S, or E or W. My spots coordinates to the left show a negative E value (ie E-34.98 instead of W34.9Shadey, and my points south of the center show a negative N value (ie N-65.34 instead of S65.34). Please see attachement. Does anybody knows how to do this?
Thanks in advance
Fri, Jun 8, 2012 at 10:35:00 AM | Settings for spot coordinates - Revit 2012
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't think it's possible.
Fri, Jun 8, 2012 at 4:08:37 PM | Settings for spot coordinates - Revit 2012
rat69
I guess you are right.
Thanks anyway.
Convert to State Plane Coordinates in Revit 2012
Wed, Nov 16, 2011 at 8:01:56 AM
Spot Dimension references are no longer valid
Mon, Dec 3, 2012 at 7:44:16 PM
Spot Coordinates on Piles
Fri, Mar 9, 2012 at 9:11:10 AM
Aquiring Coordinates
Wed, Feb 10, 2010 at 10:22:37 AM
specify coordinates at a point
Tue, Oct 4, 2005 at 12:56:17 AM
Page generation time: 1.9676
