51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Creating an attenuator family - air flow problem
Fri, Jun 8, 2012 at 9:42:37 AM | Creating an attenuator family - air flow problem
DaveCBG
I have made a basic attenuator family in Revit MEP 2012 as I couldn't find any metric ones to download, but I am having a problem in that the air flow in the duct does not carry o nthrough the attenuator. I have it set up as a duct fitting family type, and the duct connectors are set to 'Calculated' under 'Flow Configuration'. I have also linked the connectors and tried all sorts of things like playing with parameters, setting them as instance and type, using shared parameters, and using none at all, but it still will not work correctly.
I have attached the family, so if anyone has any ideas and wants to have a go at making it work then by all means try it out.
Thanks.
Fri, Jun 8, 2012 at 10:08:49 AM | Creating an attenuator family - air flow problem
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Did you look at these ? > http://seek.autodesk.com/category/Sound+Attenuators
Tue, Jun 12, 2012 at 2:21:05 AM | Creating an attenuator family - air flow problem
DaveCBG
I did, but they are all in imperial sizes, which is why I wanted to make my own.
Tue, Jun 12, 2012 at 8:05:13 AM | Creating an attenuator family - air flow problem
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe you can go under the Manage Tab, Project Units, and change the units to read how you want.
Wed, Jun 13, 2012 at 4:16:12 AM | Creating an attenuator family - air flow problem
DaveCBG
I managed to get mine working, I changed the connectors to 'Global' types, same as a Ruskin one I downloaded to see how they'd doneit, and also realised that I had placed the whole unit on the level 0 reference plane, instead of having the level going through the middle of it.
HELP with air terminals
Tue, Oct 25, 2011 at 9:44:47 AM
13
AIR FLOW GOING THE WRONG WAY
Wed, Jun 4, 2014 at 12:01:13 PM
Ductwork connected to air device displays flow in one model but not another
Fri, Nov 15, 2013 at 7:33:42 AM
Deleting an air termainal doesn't update CFM
Thu, Jul 19, 2012 at 10:35:57 AM
REVIT MEP, Diffuser Airlfow Parameter isssue
Tue, Jun 10, 2008 at 11:40:48 AM
Page generation time: 1.3234
