85 Users Online (84 Members):
Forums >> Community >> Newbies >> Tag for "count"
35 Posts No Rating |
Hi
I am trying to create a Tag for the count of my beams on a fabrication drawing..
It doesnt seem to be possible the normal way
does anyone know any workaround?
Tags will not count. You can get counts from schedules.
Yeah that is what i had figured out!I have already made the schedules with all the counts but i need the numbers on my fabrication drawings.
but do you know if there are any workarounds?.
like making a parameter that somehow makes a number equal to the count of the elements!?
This would be something for the Autodesk programmers to work on because i think this could be a popular option if possible
Not sure what you are asking. You can give elements mark numbers and that can be tagged. The numbering would be manual unless you can find an add-on to do it.
You can always place the schedule on your drawing.
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
i use macros that copy counts into tags for seating, occupancy loads and factors.
7 Posts No Rating |
Alabaster, I took a look at your site and your blog, are all your work done in Revit?
Schedules - Calculated Value does not have "Count" in the list of fields |
Thu, Oct 17, 2013 at 8:55:44 PM
Schedule Count as Percent of Grand |
Thu, Dec 22, 2011 at 10:33:17 AM
Room Schedules: Using "Count" in Calculated Vaules....??? |
Fri, Dec 10, 2010 at 1:02:21 PM
Window Schedule: "Count" not counting... |
Tue, May 31, 2011 at 3:29:57 PM
"Tag by category" of Architectural Column in Plan |
Thu, Apr 16, 2009 at 2:45:20 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
