54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Deleting Refererence Planes
Tue, Jun 5, 2012 at 8:26:44 AM | Deleting Refererence Planes
jawatts4
Is there an easy way to delete reference planes from an architectural model.  I work for an MEP firm and everytime we import the architectural model into our model, there are hundreds of reference planes.  Turning them off in VG settings doesn't work and you can't pick one, right click and have the program select all of the planes.  We have been deleting them everytime we get a new model and I feel like there's just got to be a faster way of getting rid of these reference planes.
Tue, Jun 5, 2012 at 8:34:40 AM | Deleting Refererence Planes
3.5 Stars: 395 Votes
What do you mean " Turning them off in VG settings doesn't work"?  You can turn off any category in a linked model seperatly from your settings.  VG / Revit Links tab / display settings - custom - now turn off the proper category in the linked model.
Tue, Jun 5, 2012 at 8:46:48 AM | Deleting Refererence Planes
jawatts4
That is what we are doing.  We go through VG settings and select the revit link turn options to custom and turn them off in EVERY view but this is time consuming and when we receive an updated Arch. model we have to repeat the whole process all over again.  So I guess my question is "is there a way to hide the elements one time and they stay hidden even though the revit link is updated regularly"? We update the model about once a week and it gets old having to go through VG settings every time to solve the issue.
Thanks!
Tue, Jun 5, 2012 at 8:58:08 AM | Deleting Refererence Planes
I don't think you understand.
First - You don't hide the individual items, you turn off that category ONLY FOR THE LINK
Second - Once, you turn off the category for the link in a view, it is done for good - unless you change it.
Third - When you update a model DON'T REMOVE THE LINK! - Simply reload from - the latest model (and it can be changed in name and location)
Fourth - It appears that you may not be using VIEW TEMPLATES - If not, then you should be.  You can set up a view template to do this process for all similar views and you don't have to do it then for every view - just apply the template!
Tue, Jun 5, 2012 at 9:11:29 AM | Deleting Refererence Planes
jawatts4
WWHub, thanks for the help.  We figured out steps 1-3, but it hadn't occured to us to modify our template!  Thanks for the tip!
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Reference planes have gone mad!
Thu, May 31, 2007 at 9:23:08 AM
reference planes
Wed, May 24, 2006 at 10:19:12 AM
Reference planes or gridlines when setting out model?
Tue, Jan 31, 2012 at 8:16:12 AM
Listing the Abilities of Reference Planes
Sun, Sep 9, 2012 at 9:24:07 PM
Page generation time: 0.3518
