48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door Hardware
Sat, May 8, 2004 at 7:54:56 AM | Door Hardware
SteveB
3.5 Stars: 5 Votes
How do you handle door hardware in the door properties box. I guess you need to put a key in "comments". Other ideas? Also, is there any way to have Revit report the door handing to the schedule? -Steve Brown
Mon, May 10, 2004 at 9:11:51 AM | RE: Door Hardware
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
to answer all your questions...add additional parameters to your door families. You can add a parameter called "handing" and another one called "lockset" and so on... Then in your project you can fill in these fields.
Hiroshi Jacobs
Thu, May 13, 2004 at 10:33:46 PM | RE: Door Hardware
SteveB
3.5 Stars: 5 Votes
yes, thanks. But doesnt this require modifying every door file? Steve
Fri, May 14, 2004 at 8:50:43 AM | RE: Door Hardware
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
yes but you didn't expect to not have to do any work did you? :-) What we do is give doors a hardware group and just call out the hardware group in the comment. Hardware groups are specified in our specs.
Hiroshi Jacobs
Tue, May 18, 2004 at 6:12:49 AM | RE: Door Hardware
SteveB
3.5 Stars: 5 Votes
Agreed on the hardware group in the comments. Any way to have the "hand" of the door reported?
Tue, May 18, 2004 at 5:09:39 PM | RE: Door Hardware
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
as far as the door handing, it's probably best to set your doors up with an instance shared parameter.
Hiroshi Jacobs
Fri, Mar 24, 2017 at 10:36:17 AM | Door Hardware
archigrafix
5 Stars: 4 Votes
Have a look ot Xdoor.
https://apps.autodesk.com/RVT/en/Detail/Index?id=2481590927896495348&appLang=en&os=Win64
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Nov 23, 2017 at 11:05:25 AM | Door Hardware
lorraineanne
I got this interior door http://caldwells.com/interior-doors/closet-doors at Caldwells hardware and door shop, you can check them as they also offers several door accesories and other home improvement needs.
Door hardware Schedule
Fri, Dec 2, 2011 at 11:01:23 AM
Door Hardware and Accessories
Thu, Mar 29, 2007 at 8:33:28 AM
Door Hardware
Wed, Nov 16, 2011 at 7:27:33 AM
Door Hardware and accessories
Wed, Mar 28, 2007 at 10:15:47 AM
Door schedule
Sat, Nov 8, 2014 at 7:47:18 AM
Page generation time: 19.5056
