29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit MEP 2012
Mon, Jun 4, 2012 at 10:55:23 AM | Revit MEP 2012
tmassey
tmassey Avatar
Need a quick answer if possible on these three questions.
How can I change the diameter of the plumbing symbol in plan view. I know how to change the size of the plumbing line. Plumbing lines are different sizes but the plan view symbol stays the same size. I want to edit the symbol on plan to make it smaller.
Pipe Size Tag. I have selected the tag to be horizontal but it still shows as vertical unless I move the leader slightly off axis. If the leader is straight the text becomes vertical.
Some pipe connections on plan show a gap from the pipe to the tee or elbow. In 3d or section the pipe is connected. On plan it shows the line as broken before the connection. I have to manually select each pipe and connect it on plan.
Cheers.
Using Revit Architecture 2012
Mon, Jun 4, 2012 at 11:57:51 PM | Revit MEP 2012
agosztyla
Mate only thing i can think of for the symbol are to open them in your libary where theyre save and edit them then load in.
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
TRIMMING PIPES - MEP 2012
Fri, Sep 21, 2012 at 9:06:37 AM
PIPE ELBOWS MISMATCH in F-REVIT 2012 MEP
Mon, Apr 15, 2013 at 2:52:28 PM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
Revit MEP 2012-View Range
Fri, Apr 12, 2013 at 7:22:48 AM
Page generation time: 1.3678
