106 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Escalator Help
Mon, Jun 4, 2012 at 5:11:25 AM | Escalator Help
bjwson
2.5 Stars: 3 Votes
Hi All,
I'm having trouble to add these parameters and make it work, when loaded into a project.
can some-one here add these parameters...,or guide me. (i have marked them in RED)  i got this family from here itself.
My request is that these dimensions (need to be converted into parameters) are not fixed dimensions,
therefore i should be able to modify them independently.
Pls. see attached.
I'm Using Revit Architecture 2012
cheers,
W
Mon, Jun 4, 2012 at 6:16:21 AM | Escalator Help
4 Stars: 203 Votes
CREATION FAMILIES RULE 101 - Create "Ref. Planes", create dimensions between ref. planes and not from objects, select the dimension and create the parameter, create obj. and constrain to ref. planes.
Good luck
Tue, Jun 5, 2012 at 9:47:25 AM | Escalator Help
bjwson
2.5 Stars: 3 Votes
thx. for the tip. i could do most of it. but if you see (in 3d view) the family i've attached, i need the handrail quadrant to be at where i have drawn the model lines....why am i not able to make it work. pls. help.
thx.
W
Tue, Jun 5, 2012 at 1:02:33 PM | Escalator Help
4 Stars: 203 Votes
Edit the PATH and sketch like you want.
Wed, Jun 6, 2012 at 12:50:56 AM | Escalator Help
bjwson
2.5 Stars: 3 Votes
thx. let me try.
Escalator
Mon, Jan 9, 2012 at 4:14:52 PM
11
Parametric travelator/escalator?
Sun, Jan 24, 2016 at 7:54:12 PM
Editing height of escalator?
Fri, Mar 6, 2009 at 5:28:41 PM
parameter change
Sat, May 9, 2009 at 1:43:21 PM
Families' View Range
Thu, Jan 21, 2010 at 8:43:30 AM
Page generation time: 0.1935
