35 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Elipse
is there a way to snap to the focii of a revit drawn elipse?
Not that I am aware of.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2921-Customiz2921/2931-Project_2931/3069-Snaps3069/3074-Object_S3074
Yes. If you turn On the focus marks, you can snap to those points as quadrants.
Planta1 Revit Online Consulting | info@planta1.com |
Great! How do you turn them on?
I'd be interested to know how to turn them on also?
I found this post which may be of help. But after searching I could not find a way to turn on focus marks.
http://autodesk-revit.blogspot.com/2011/08/revit-2012-dept-of-unfair-ellipses.html
Select the ellipse, find the property, and turn it on.
Edited on: Wed, Jun 6, 2012 at 10:44:23 AM
That works! Tested it just to be sure.. Length of triangle perim between focii and to any perimeter point is all equal.
Elipse and slanding |
Fri, May 26, 2006 at 2:33:20 AM
Elipse Sweep |
Tue, Sep 6, 2005 at 1:09:43 PM
Someone help with this modeling |
Mon, Jul 11, 2011 at 1:15:54 PM
Problem with mass |
Sun, Jan 29, 2006 at 10:52:52 PM
Editing masses |
Mon, Apr 18, 2011 at 5:17:56 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
