28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> exterior glazing systems
7 Posts No Rating |
Hi There
I would like to create a Storefront/Curtain wall/ Exerior glazing that creates vertical grids and 2 x horizontal grids at set measurements. this wall also needs to make the bottom panel solid as I draw the wall.
If anyone can tell, show or direct me to a tutorial that can teach me this it would be much appreciated.
Regards
marco
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
You are not clear in your question. The answer to the one that you have written is:
Simply create a new CW type that has a fixed spacing for the horizontal and the vertical grids.
I am sure that is probably not your question. If you mean a pattern of different spacings? ... Then the answer is you can't. Simply create one, then copy it to other locations and edit accordingly.
Rendering Exterior Glazing |
Mon, Feb 20, 2012 at 2:45:05 PM
Mullion offset from exterior glazing |
Sun, Feb 14, 2010 at 10:05:21 AM
transparency on exterior elevations |
Mon, May 21, 2007 at 5:51:15 PM
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Problem with glazing and wall alignments |
Thu, Jan 24, 2013 at 10:16:59 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
