Forums >> General Discussion >> Revit Project Management >> Import ifc to Revit MEP
Thu, May 31, 2012 at 6:42:25 AM | Import ifc to Revit MEP
abraxaz
I am absolutely new to Revit as a user and my focus is on operability between different applications. The problem is that I can not se theIFC file that I import to the application. I assume that I should change something in IFC options regarding template or class mappings, but have no idea of what and how.I tried to do the simplest experiment possible: draw a duct in a new Revit MEP project, exported it as IFC and tried to import it back to the application, but again nothing was visible on the screen. Since I thought maybe the problem is just in viewing parameters, again I extracted the project as IFC and checked it with Solibri. There was nothing there! So I conluded that I need some knowledge for "importing" IFCs to Revit MEP which I did not find on the net.Any solution?
Sun, Jun 3, 2012 at 5:32:49 AM | Import ifc to Revit MEP
4 Stars: 203 Votes
I don't work with MEP but I exported a simple proj. to IFC 2x3 and open in Solibri and it's working
Inserting IFC into AutoCAD MEP
Tue, Feb 12, 2013 at 2:01:28 PM
No Import - Maximum size of IFC imports?
Sun, Jul 10, 2016 at 6:56:30 AM
importing IFC files in to MEP 2011
Mon, Feb 11, 2013 at 10:53:22 AM
Importing IFC into Revit MEP 2013
Wed, Jul 11, 2012 at 7:40:52 AM
3D CAD to Revit
Wed, May 4, 2011 at 7:59:51 AM
Page generation time: 4.6648
