51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Curtain Wall Grids Adding Automatically
3 Posts No Rating |
Hello, Sorry if this has been covered before, but I couldn't find it by searching.
I am using Revit 2012. In a curtain wall, I have the horizontal grid pattern set to Fixed Number. I specify a number and adjust the spacing to suit, but every time I return to the model, it has reverted back to a default grid (with the custom grids also present, so double the number set in the properties). This is very annoying to have to keep adjusting, and I have almost issued elevations showing doors (curtain panel doors) at 1.6m high!
Is there a way to lock the revised grid pattern without having to pin the entire wall? Thanks
If you want to edit the spacings after placement, there are two metods. I only do one of these. After placement, I always change the CW definition to one that has no preset conditions. You will see this message: "Type generated gridlines will become non-associated due to changes in the type. Press delete if you wish to remove them instead." This is OK because this is what you want.
3 Posts No Rating |
That sounds like a simple enough workaround. That should save me many headaches (and a few ?!*@!'s)
Thanks!
Random Diagonal Curtain Grids in a Curtain Wall |
Wed, Jul 6, 2011 at 6:57:03 AM
non parallel curtain wall grids |
Sat, Apr 28, 2007 at 12:54:05 AM
Curtain Wall Grid Angle |
Tue, Feb 15, 2011 at 2:42:32 PM
Slanted curtain wall help! (pic attached) |
Wed, Oct 22, 2014 at 6:02:39 PM
revealing hidden curtain grid |
Mon, Sep 8, 2008 at 3:55:02 PM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
