22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Problem With Linked RVT Files and Associated Levels
Tue, May 29, 2012 at 12:33:33 PM | Problem With Linked RVT Files and Associated Levels
fadinsky
Hello everyone,
I am developing a multi story apartment building, where the apartment type changes per floor, and they subject to change in the future. In order not change the apartment type for every floor everytime, I decided to develop a RVT file for each apartment type, and link each apartment into a master project file.
Here is the structure:
Apartment Type Shell --> Apartment Type (A,B,C...) --> Buildings Complex
Unfortunately after importing the RVT into the master project, it is always associated with Level 1 on the master project, and I cant change the association of it.
So when I create a schedule all of the apartments appear on Level 1...
I hope I explained my self well enough.
Thank you all for your future advise.
fadinsky
Tue, May 29, 2012 at 12:52:49 PM | Problem With Linked RVT Files and Associated Levels
You would have to have a seperate rvt file for each instance....
You would be better off to have these as groups for model purposes - not annotation.  Note and annotate the apartments in the seperate file.  Group all of the model components then copy that group to clipboard and paste wherever you need them in the main model.
Tue, May 29, 2012 at 1:42:20 PM | Problem With Linked RVT Files and Associated Levels
fadinsky
WWHub thanks for your reply,
It seems to be the only way. I don't understand why aren't there options regarding the association of the link RVT to the model. I am using Revit 2011 Architecture. Has it changed in 2012 or 2013?
Thank again.
fadinsky
Tue, May 29, 2012 at 2:10:14 PM | Problem With Linked RVT Files and Associated Levels
Nothing has changed, this is the way it has always been.
getting the levels and elevation from linked file
Sat, May 14, 2016 at 5:25:06 PM
Deleting Linked RVT Categories
Fri, Feb 3, 2006 at 9:40:29 AM
Levels in linked files
Tue, May 24, 2016 at 9:40:38 AM
Linked rvt into another rvt
Tue, Jan 20, 2009 at 12:21:13 PM
visibility problem with linked files
Thu, Sep 11, 2008 at 11:52:11 AM
Page generation time: 7.5064
