103 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING
Tue, May 29, 2012 at 9:55:30 AM | LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING
kkakizaki
Hi all-
We have an issue of losing visibility settings (hide/show worksets) after synchornizing. It seems to upload another user's visibitlity setting, as we are working in the same view. Revit must have a way to not have to re-set these settings after every synchornization... any help would be appreciated! Apologies as this may be a noobie question.
Thanks,
K
Tue, May 29, 2012 at 10:08:43 AM | LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING
Learn to use view templates to control views placed on sheets and make sure you assign them to the view.  You can never stop someone from altering VG settings for a view but with view templates, you can be assured that all views are as they should be by applying the default view templates to all sheets prior to printing.  A very easy process.
We encourage our users not to work in sheet views when working with model emements.  Instead, we have them create a working view, title it as such (add users name) and put it in a working folder.
Tue, May 29, 2012 at 10:08:54 AM | LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING
TKennedy
4 Stars: 7 Votes
The settings in V/G are not user specific, they are view specific.
error when synchronizing
Mon, Jan 28, 2013 at 4:03:00 PM
Hide Mullion Profile When the Visibility Setting is Fine
Mon, Mar 13, 2017 at 10:32:49 AM
Central/Local File Synchronizing Issue
Sun, Jun 23, 2013 at 2:33:21 PM
Visibility setting for a arch seal
Wed, Oct 19, 2016 at 11:22:57 AM
Setting User Interface
Tue, Aug 14, 2007 at 5:03:41 PM
Page generation time: 1.1827
