Forums >> Revit Building >> Technical Support >> Has anyone find an accurate way of creating topo Surface from import
136 Posts No Rating |
Hey all,
So far I've just dealt with the fact that I might get a few spikes and will have to smooth them out manually when importing from surveyors topo points. However I've just received the attached file. It looks really tidy when orbiting in AutoCAD as the surveyors have shown retaining walls well etc. However when i use this to create my Topo Surface I get alot of really nasty spikes all around my site due to revit trying to create it's own additional triangles!
Can anyone tell me the best way to deal with this so that I can get a site hich is somewhere near correct in Revit, (I don't really want to go round guestimating all of the spiked points as there are hundreds, possibly thousands if i checked properly).
Any fast help will be much appreciated.
For Architectural Services visit www.jrpcad.co.uk |
Sorry but you need to create more points (at the base) in that retaining wall, also, if you have your building in your project why don't you create a PAD and you solve half of your problem?
You might also try simlifying your surface - Read this HELP topic:
Simplifying a Toposurface
it would be handy if I could take the mesh into another 3D package and subdivide the triangles to create lots more points, then after that looking at simplifying as hub said. I'll let you know how I get on
Mmmm I couldn't find the thread Hub, do you have a link for it by chance?
Edited on: Tue, May 29, 2012 at 7:26:24 AM
JRPcad - That's the trouble with wikiHELP!!!! I hate it. we only use the installed help file here.
Simplifying a surface can improve system performance, particularly on surfaces with a large number of points.
- Open the site plan view and select the toposurface.
- Enter a value for surface accuracy, and click OK.
- Click
(Finish Surface).
Ahh cool, I thought you meant there was some kind of work around using it. I've used simplifying before, it's good for "decimating" te surface to keep the comp running well, but won't get rid of the spikes for me, I think if i can increase the number of triangles then decimate in revit, it will hopefully improve things.
Civil 3d surface to revit topo surface |
Thu, Oct 13, 2011 at 7:14:34 AM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Creating Topo using an image |
Mon, Feb 21, 2011 at 2:18:32 PM
Deleted Topo Surface |
Fri, Apr 2, 2010 at 3:54:58 PM
Members: | 2115259 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
