Forums >> Workflow & Implementation >> Training >> Curtain system > glazing panel matherial
43 Posts No Rating |
Hi to all!
I need help with curtain system by face, with glazing panels,
I can dublicate the existing 1500X3000mm , can change dymesions , panel to glazing,
but I CAN'T FIND where to change the glazing colour, matherial , and I can't open and edit that system like a family ...
where I must look? I want to make my custom colour of a glazing panel curtain system...
Thanks
revit 2013 (architecture/structure)
(sorry for my bad english)
Edited on: Sun, Jun 3, 2012 at 9:15:13 AM
Hover over your mouse in one panel and use your TAB key, (tab, tab, tab...) until you select the panel, then go to properties>edit new and you will see a "material" parameter.
Thank you very much !!! Yes it was there , I made tht... and I have another question ... I will make screenshot , I will post here or in other thread... something with massing ...
I have cutted thin volumes with that big , at tangent faces I made glazing panel/ curtain system by face but one of them make that , what's wrong , where to find the problem, what to change, it cuted but i doesn't want to make curtain system , it show it but after clicking cancel or delete it disapears ... all that in one inplace mass...
http://img21.imageshack.us/img21/5905/forumrp.jpg
this at the midle , is capricious
Edited on: Wed, May 30, 2012 at 12:59:01 AM
Edited on: Wed, May 30, 2012 at 1:00:03 AM
Look the error, "A panel or a mullion is probably too small"... try to create that by zone, one by one until you have the error and check what is wrong....
Thanks, you saved me, yes I had selected 3 zones/faces at a time, but when now I selected by step creating 3 systems not one , it jumped over that error, some messages appears but that don't matter , it works ... My second revit student-sketch-project, and I like that program more an more ...
I'm glad to hear that....
Edited on: Mon, May 28, 2012 at 1:02:36 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Butt Glazing Non-System Curtain Panels |
Wed, Nov 12, 2014 at 1:28:25 PM
Replace blank curtain wall panel |
Mon, Oct 12, 2015 at 12:13:56 PM
missing empty curtain wall system panel |
Thu, Aug 4, 2016 at 7:17:33 AM
sloped glazing in schedule |
Wed, Jun 17, 2009 at 10:18:35 AM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
