32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Need Rendering help in revit 2012
Sun, May 27, 2012 at 2:02:11 AM | Need Rendering help in revit 2012
tectacoma
tectacoma Avatar
I could use some expertise help with the Rendering and lighting process.
Attached is a rendering of a project of mine.
1. The windows still come out dark - I turned the pod lights to 320W and changed it to 3200K
2. The exterior lights don't shine although I didn't turn the lighting off...
3. How can I create a red sky or any other sky besides the typical blue/gray sky revit always reverts back to?
I changed the settings in graphic display options but when it comes to rendering it, it looks completely differnent. I have changed the time/date, adjusted exposure as well.
Any help and tips are greatly appreciated.
Sun, May 27, 2012 at 4:26:52 AM | Need Rendering help in revit 2012
4 Stars: 203 Votes
The problem is in your posts lights, change the material of the light glass and turn on "Self ilumination" like you can see and increase the Wattage 1000x when you are rendering an "Exterior with Sun and Artificial", if the lamp don't have any glass then create one....
About the "RED sky or any other" in the Render options > Backgroud > Style change the sky to image and select the sky you want...
Edited on: Sun, May 27, 2012 at 4:33:36 AM
Sun, May 27, 2012 at 4:34:25 AM | Need Rendering help in revit 2012
4 Stars: 203 Votes
here:
Sun, May 27, 2012 at 11:41:22 AM | Need Rendering help in revit 2012
tectacoma
tectacoma Avatar
thanks Typhoon...I played with the background image before but I thought the "gradient" tool would be somewhat useful for
this but guess not. I tried to increase the wattage of the interior lights as well as the outside lights and it did made a big differentce.
I'm still trying to make the rooms look more illuminated when I render the exterior -
BTW - I couldn't find those street lights you have...what's the name for those?
Again, thanks for the help.
2012 Rendering Advice
Tue, Sep 27, 2011 at 7:17:33 PM
Wall Curtains and Rendering view as solid instead of Glazing 2012 version
Tue, Jan 24, 2012 at 1:28:32 PM
Revit 2012 problem rendering RPC trees and people
Wed, Aug 31, 2011 at 6:38:54 AM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2012 crashes at splash screen HELP!!!
Fri, May 17, 2013 at 1:13:24 PM
Page generation time: 1.8177
