95 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Edit profile on a sloped wall
![3 Stars: 1 Votes](/images/stars_3.gif) |
I am working on a very complex mass that has walls that are angled in both the x and z directions. I want to be able to create two different walls on a single face, but Revit will only allow me to apply a wall to the entire face. Is there some sort of work around for this? I have already tried splitting the mass faces.
Im using Revit 2012
Edited on: Fri, May 25, 2012 at 8:34:32 AM
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Can you attach a pic of the mass you are using. If you split the face of the mass you should have 2 different faces and be able to apply a wall per face
Don't forget you can use "In-Place" families too....
Here's a pdf of the mass. I've also attached the file I'm using.
In Place familes wont really work because Im layering so many walls onto the mass.
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
Keep in mind when designing a structure that someone has to build it. They are tough enough when done simply.
How to Edit Profile of Sloped and Curved Walls? |
Thu, Sep 13, 2012 at 11:59:07 AM
Sloped terrain and sloped foundation wall |
Thu, Sep 3, 2009 at 1:57:36 PM
Sloped wall - mass in place - profile line level |
Thu, Oct 18, 2018 at 8:55:41 AM
edit wall profile... what? |
Mon, Feb 7, 2011 at 1:58:19 PM
Edit profile on a curved wall |
Sun, Aug 29, 2010 at 11:30:00 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
