81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> In Place Wall MAterial
Thu, May 24, 2012 at 9:59:13 AM | In Place Wall MAterial
lauralievano
Im using revit arch 2010... Created a wall in place to get a curved slopping down under the curved stair.
Is there a way to apply the stone pattern and the other wall properties (which is concrete structure with stone finish on both sides) to the in place wall so it reads as one single wall?
Thu, May 24, 2012 at 10:26:25 AM | In Place Wall MAterial
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could join your walls and add the material to your in place wall.
Thu, May 24, 2012 at 10:27:33 AM | In Place Wall MAterial
4 Stars: 203 Votes
Edit that in-place wall, now create 3 walls, not one, with the thickness and material parameters for those walls like you want.
Thu, May 24, 2012 at 12:59:31 PM | In Place Wall MAterial
lauralievano
thanks! 8]
in-place component wall help!!
Wed, May 8, 2013 at 12:15:22 PM
"Paint" and In-Place Component Material Bug?
Thu, Apr 14, 2016 at 2:47:44 PM
component with material and recess wall
Thu, Sep 10, 2015 at 7:22:24 AM
Ploblem with material take off
Thu, Jun 21, 2012 at 6:41:11 AM
Brick Pattern on In-Place-Mass is Lignter than on Wall
Sat, Mar 19, 2016 at 11:31:57 PM
Page generation time: 1.4423
