98 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> cutting a HSS tube
Wed, May 23, 2012 at 1:32:55 PM | cutting a HSS tube
dhoff13
Is it possible to cut a hole out of a HSS tube in revit 2013. I need to put holes in one to mount speakers/lights/etc. I've attached a picture, hope that explains what I'm after.
106747_tube_cut.tif
Wed, May 23, 2012 at 1:38:57 PM | cutting a HSS tube
Have you tried a face based void family that cuts its host?
Wed, May 23, 2012 at 1:45:45 PM | cutting a HSS tube
dhoff13
no, I've gotten a hole with the "opening: by face" tool but it goes all the way through both sides, whereas I only need it cut on one side.
I've never tried to make a revit family before, will creating a face based void family be diffucult?
Wed, May 23, 2012 at 1:51:05 PM | cutting a HSS tube
No ... and a good time to start learning.
Wed, May 23, 2012 at 1:54:16 PM | cutting a HSS tube
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Families are quite easy to make, and open up a whole new realm of revit's power.
If you want, I think you could "model in place" a family in your project--IE, just a void extrusion(or sweep, I prefer sweeps in almost all cases) in the structural column category, and use "cut geometry" with the column while still in the family editor mode.  (it won't let you finish if the void isn't cutting anything yet.)
model-in-place families are sometimes nice, and sometimes a burden--but what's nice is that you can create then in situ, and use the project as a reference.
Modeled-in-place voids didn't cut a structural beam in my project.  Not sure why not--most categories work.
Edited on: Wed, May 23, 2012 at 2:10:09 PM
Wed, May 23, 2012 at 2:03:52 PM | cutting a HSS tube
Its - your right, but a face based, fully parametric - width x height x depth family will be useful on SO MANY projects! .. and an in-place is really best used in only one place.
We use ours for wall nitches, floor holes, floor depressions, openings or depressions in any surface....
Wed, May 23, 2012 at 2:06:23 PM | cutting a HSS tube
dhoff13
thanks guys, I really appreciate the speedy responses
Time to go learn families
Need help: modeling tube to tube intersection w/ in-place families
Wed, Nov 11, 2009 at 7:15:37 PM
Cannot add sub-family to HSS Steel Tube Sections
Thu, Sep 22, 2011 at 3:02:36 PM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:46 AM
Cut a window into a tube
Mon, Feb 13, 2006 at 4:29:01 AM
Wiring a 3 tube light
Thu, Jun 23, 2011 at 3:01:49 PM
Page generation time: 8.6257
