58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Tue, May 22, 2012 at 7:39:04 AM | Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Polar
Hi Guys,
So I'm working on a project with lots and lots of bricks assembled into interesting profiles. This is an existing building. If they didn't win a brick manufacturer's design competition I'd be surprised.
I attached a wall section here along with a photo, an isometric view and a perspective view.
Questions:
1. Ideas for radial brick work
2. Ideas for the brick sill and wall below at an angle
3. Was thinking of making a wall with sweeps for the projecting brick work
5. Better ideas than an imbedded wall with a profile to get the arch modeled
Thanks!
106678_Wall-Section-Projecting-Brick-Work.PNG106678_Masonry-Arch-Progress.PNG106678_Masonry-Arch-Progress-as-embedded-wall-with-arc-profile.PNG106678_Masonry-Arch-Radial-Brick-Pattern.PNG
think it - build it
Tue, May 22, 2012 at 9:16:49 AM | Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
For sloping brick sills, we use an in-place void to cut the sill area, then we add an in-place sweep to create the sill.  You can also add this to the window family if you have a lot of instances.
I never like to use walls with sweeps defined in the wall type because you can't control them phisically or visually.
Tue, May 22, 2012 at 12:52:23 PM | Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
4 Stars: 203 Votes
Array Radial for the arc, create a generic model face based family with instances parameters...
Tue, Jul 24, 2012 at 5:28:16 AM | Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Polar
Hi Typhoon - thanks I followed your advice and it worked pretty well.
think it - build it
Tue, Jul 24, 2012 at 5:31:30 AM | Masonry Wall Modeling - Projecting Brick Courses and Masonry Arches
Polar
I guess the next thing might be writing an equation to calculate the number of bricks in the arch give the radius and making that part of a family.
think it - build it
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:05 PM
Revit Hatch Pattern w/ alternating masonry courses?
Tue, Nov 17, 2020 at 2:37:21 PM
Masonry Quoining/Details
Wed, Feb 28, 2007 at 12:44:55 PM
Modeling a Masonry screen wall
Wed, Oct 1, 2008 at 12:50:26 PM
Curved Masonry Walls
Thu, Dec 13, 2007 at 12:17:28 PM
Page generation time: 3.1231
