57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Concrete pan slab
Fri, May 18, 2012 at 7:25:16 AM | Concrete pan slab
vrmoreno3
Anyone create a revit floor that is a concrete pan "waffle" slab?
Fri, May 18, 2012 at 8:52:14 AM | Concrete pan slab
You can use the same process as in this CADCLIPS video: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20480
Fri, May 18, 2012 at 9:07:16 AM | Concrete pan slab
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I haven't tried this yet but I found this solution while searching how to create a waffle slab.
http://books.google.com/books?id=vEBG3ZyzdPEC&pg=SA7-PA22&lpg=SA7-PA22&dq=revit+waffle+slab&source=bl&ots=XmsN7buL91&sig=2LzWRVQQ6PKY0OrxqNZyW6galS4&hl=en&sa=X&ei=olS2T9j7H8ry2QXG6c2eCQ&ved=0CGYQ6AEwAg#v=onepage&q=revit%20waffle%20slab&f=false
I also found a few options to go with..
http://bdmackeyconsulting.com/waffle-slab/
Dimensioning a Sloping Concrete Pan Joist Roof
Sat, Feb 14, 2009 at 11:07:40 AM
Stair to Slab Connection
Tue, Jun 5, 2007 at 3:52:46 PM
Concrete Beam and Slab
Mon, Jun 3, 2013 at 2:47:31 PM
show concrete only
Sun, Nov 18, 2012 at 10:16:21 PM
Concrete Slab Edge Angles
Wed, Dec 7, 2011 at 12:35:24 PM
13
Page generation time: 0.4197
