60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Tagging Subregions in Topography
Fri, May 18, 2012 at 5:19:12 AM | Tagging Subregions in Topography
keeza09
Hello,
does anyone know a way that I can tag my subregions on my topographical plan? I have given them materials and I want to be able to tag them to show this. It would be useful if i could either tag the material type itself or even if i could tag the 'mark' so that i could give a reference number to that type of material
i have tried using the 'material tag' as well as the 'tag by category' but neither seem to allow me to select the subregions
i am using revit architecture 2011
thanks in advance,
kieran
Fri, May 18, 2012 at 10:38:43 AM | Tagging Subregions in Topography
keeza09
bump
Fri, May 18, 2012 at 11:22:19 AM | Tagging Subregions in Topography
It does not appear that you can tag topography at all for both material or element.  You could use keynote tags - user.  It will not automatically assign to the areas by type but your text would be consistant and controllable through your keynote file.
Mon, May 21, 2012 at 3:07:14 AM | Tagging Subregions in Topography
keeza09
WWHub, Thanks for your reply.
oh ok. how do i insert the keynote parameter into the subregion then? I dont really know how keynotes work that well
Mon, May 21, 2012 at 7:45:10 AM | Tagging Subregions in Topography
You will not be able to add the keynote parameter to the subregion.
Copy you default keynote file to your project dirctory and rename it accordingly.  These files are simple txt files - don't change that type!  Edit the file and add the notes you need.  Then in the file, open the keynote settings and browse for this file so it will be linked.
You will have to do this each time you change it while in session, otherwise it is reloaded each time automatically once linked.
Now load your keynote tag.  There are two types of tags, keynote number and keynote text.  You will want keynote text.  From the annotations, keynote pulldown, pick user.  Point to your subregion and pick your note from the pulldown when it pops up.
Subregions on Topography Take Ages to Process & Regenerate.
Mon, Mar 23, 2015 at 7:24:12 AM
Gaps between Subregions
Tue, Sep 23, 2014 at 11:08:36 AM
Subregions and Topography
Tue, Aug 19, 2008 at 3:04:37 AM
problem pads and subregions , weird depression on topography
Sun, Mar 22, 2015 at 1:46:45 PM
Surface Hatch Pattern on Topography/Subregions
Fri, Oct 24, 2008 at 11:30:56 AM
Page generation time: 3.0867
