94 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> A Problem with Voids
Thu, May 17, 2012 at 2:18:12 PM | A Problem with Voids
KJMR
I created a family that has some trumpets for a tieback along with some voids to cut away from a concrete panel when inserted into a project. All elements were create by using the Extrusion tool. when i go into the project and insert all families the voids that i created to cut away from the concrete panels don not cut. Can anyone help me with this issue?
Thu, May 17, 2012 at 3:50:51 PM | A Problem with Voids
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you upload the family to take a look at.
Fri, May 18, 2012 at 3:24:37 AM | A Problem with Voids
4 Stars: 203 Votes
What kind of family is that? Generic model? Wall based? face based?
In your family, those voids are cutting the Object? Did you used the "Cut Geometry" tool?
Fri, May 18, 2012 at 7:25:16 AM | A Problem with Voids
KJMR
it is a Generic model, sorry i cannot  upload the model because of confidentiality issues.
Fri, May 18, 2012 at 8:38:17 AM | A Problem with Voids
The void has to be in the family and it has to cut it there.  Did you do that?
Fri, May 18, 2012 at 8:41:20 AM | A Problem with Voids
KJMR
No i left the void hopin that it would cut the cincrete when inserted into the project
Voids in Array cuts all elements, instead of only some
Tue, Jan 22, 2019 at 4:09:03 PM
Wall by face on curved solid - VOIDS not seen
Mon, Jul 29, 2013 at 1:29:55 PM
Cutting with Voids outside of families
Wed, May 23, 2012 at 7:53:30 AM
Aligning Voids
Thu, Sep 15, 2011 at 1:29:55 PM
Voids
Thu, Jul 10, 2014 at 7:31:16 AM
Page generation time: 0.9539
