65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linking model is not showing in the schedule
Thu, May 17, 2012 at 11:31:59 AM | Linking model is not showing in the schedule
ArchiGirl08
Hello,
I am sure it is an easy fix, however I am unable to found what needs to be done.
I am linking architectural model into my model no data shows up in the casework schedule. There is no room numbers in the model either. Everytime architect does chanches in the model and uploads it, I have to tag rooms over again. Could you please help? I am working in Revit 2012.
Thank you very much!
Thu, May 17, 2012 at 1:20:56 PM | Linking model is not showing in the schedule
IF YOU WANT TO SCHEDULE LINKED ITEMS, YOU NEED TO CHECK THE BOX IN THE SCEDULE TO INCLUDE LINKED FILES.
Thu, May 17, 2012 at 1:26:54 PM | Linking model is not showing in the schedule
ArchiGirl08
Thank you!
I ahve checked the box you suggested, however there is no room numbers nor room names are displayed.
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:10 AM
Linking models issue- coordinates
Tue, Jun 19, 2012 at 10:28:14 AM
Creating a Schedule showing all Assembly Codes
Tue, May 17, 2005 at 2:48:24 PM
Rooms not showing up in room schedule, please help
Sat, Oct 27, 2012 at 10:52:35 AM
Multi-Category Schedule with Links
Wed, Aug 10, 2016 at 6:23:57 PM
Page generation time: 1.3989
