43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Toposurface following a pattern
I have a job where in the landscaping we are trying to show mulch in the shape of Alaska. I created a general toposurface with all of the grading at 0'-0" (use to be a soccer field so were just showing it flat). Then my thought was to create a sperate toposurface in the shape of Alaska which starts at 0'-0" and rises up with mulch to about 2'-6". The problem I am having is when I put my 0'-0" points in the do not stay following the outline of the state like I want and end up joining across the 0 points (see top image, blue line) and slope up from there instead of the outline of the state (bottom image). I understand why it is doing what it is doing but my question is how can I create what I'm tying to accomplish so that it keeps the shape of the state? Should I be using a mass instead? I'm stumped!
Edited on: Wed, May 16, 2012 at 1:14:33 PM
Increase the number of points in that topo, you will need only one surface for that, not two.
Thanks!
Toposurface pattern Depth |
Wed, Feb 12, 2014 at 8:52:55 PM
Toposurface cut pattern Not showing in section |
Wed, Jan 13, 2010 at 12:51:34 PM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
I can't see the pattern on a subregion of toposurface. hence can't rotate it. |
Sun, Aug 2, 2015 at 2:37:12 PM
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
