60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> REVIT 2013 materials library
Wed, May 16, 2012 at 9:14:03 AM | REVIT 2013 materials library
hoffmanr
wow my materials library is extremely slow... anyone else having the issue with 2013?
Wed, May 16, 2012 at 10:24:41 AM | REVIT 2013 materials library
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I had this problem the other day but a simple restart of revit and my computer fixed the problem for me.
Fri, Jul 13, 2012 at 6:10:03 AM | REVIT 2013 materials library
matthewh75
3 Stars: 3 Votes
I have this problem constantly, it seems to take an age to fire up & restarting just doesn't fix it. Anythning I can change in the settings / file locations to speed this up as it's totally frustrating!!!!
Fri, Jul 13, 2012 at 1:52:36 PM | REVIT 2013 materials library
hoffmanr
I still have issues with a slow library but have noticed only one thing that can help... make sure if you are creating custom materials - check the file size of the .jpg you are mapping to- keeping this file size below 1mb can greatly improve efficiency/speed of materials library.  I am still not a fan of this new materials library in 2013 as it could be simplified and have the same end result- too many windows that do not serve a purpose- especially if you are creating custom materials(which by the way not takes twice as long because you have to duplicate not only the material but also the "host" material) hopefully autodesk will clean this up in 2014.
Fri, Aug 31, 2012 at 11:13:31 AM | REVIT 2013 materials library
secdy66
Also having same problem with material library in 2013.  It's terrible! Every year they update Revit it only gets worse.  Instead of moving all the tools around so they are harder to find and changing the way the material library looks (which used to work perfect) they need to focus on making Revit actually work instead of it freezing up all the time or exiting out of itself and losing your work.  I feel like I have to save every 2 min!  Fed up with it and extremely frustrated!
Fri, Aug 31, 2012 at 11:30:16 AM | REVIT 2013 materials library
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
have you guys noticed the random UVW mapping in the texture editor? or is just me
Fri, Aug 31, 2012 at 1:23:17 PM | REVIT 2013 materials library
hoffmanr
Random UVW mapping... just another bug that needs fixing... definitely noticed.  keeping my fingers crossed for a cleaned up Revit in 2014.  I dont need any "new" features.  I think if autodesk wants to make this program a standard (which i know thats the intent) they should work on getting manufacturers together and beef up their standard libraries. Dont get me wrong their are a lot of sources out there including Revitcity but have you ever tried to create an MEP Library on your own?  Im sure the thought behind not pushing more libraries is they see it as competition for the companies already out there trying to sell content but if they cant put all of there energies into creating a truly flawless program they better be working on something.  haha- sorry for the rant... back to random uvw mapping - have noticed there are times when the only way out of this is a restart of Revit.
Wed, Feb 27, 2013 at 3:44:18 PM | REVIT 2013 materials library
BERLINBONDI
To speed up the library set the VIEW TYPE to TEXT VIEW.
Thu, Feb 28, 2013 at 8:38:13 AM | REVIT 2013 materials library
andy777bennett
a restart of revit does help, and I find that using custom high-res materials over a network slow it down too.
Under the manage ribbon you can purge unused, click select none, and scrol down to materials and get rid of ones you know you will not be using
Fri, Mar 1, 2013 at 9:17:53 AM | REVIT 2013 materials library
matthewh75
3 Stars: 3 Votes
Berlinbondi - how would you do this view change? Cheers!
Wed, Mar 13, 2013 at 9:41:25 PM | REVIT 2013 materials library
#11
BERLINBONDI
Change all the fly outs in Material Browser and Asset Browser to Text View.
Hope this helps.
Cheers
Fri, Mar 15, 2013 at 3:15:31 PM | REVIT 2013 materials library
#12
sroreilly
I'm ALWAYS having slow mat list issues.... Lots of things seem to take FOREVER in r 2013. Updated the vid card & drivers & that didn't help.
I hate the new material list thing. Painting takes a lifetime!
And, a minute ago, while trying to change a colour, Revit just shut down without warning. This release bugs me, big time!
The change in the stairs is not enough to make this old gal happy.....
REVIT 2013 Materials Library Video Tutorial
Tue, May 28, 2013 at 5:12:56 AM
13
How to get more Materials in the library (Revit Architecture 2012)
Fri, Jul 8, 2011 at 1:01:21 PM
materials
Sat, Nov 29, 2008 at 6:09:56 AM
Custom Material Library Problem
Wed, Nov 13, 2013 at 4:18:49 PM
2018 Revit Materials Library
Thu, Jun 1, 2017 at 12:44:37 PM
Page generation time: 1.7055
