79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked Cad File Help
Wed, May 16, 2012 at 8:00:03 AM | Linked Cad File Help
cundall
I have just started a new project and I have come across a problem which I cannot get my head around. I have linked in a cad file into my new project which I got from the architect into a project north view which gives me this message:
‘’This project and the linked file do not share the same coordinate system. The link’s world coordinates will be aligned with this projects shared coordinates.’’ Which is fine.My problem is the linked cad file comes into my PROJECT NORTH VIEW as it would look in true north. I need the linked cad file to be rotated to project north but im struggling
Can anyone tell me what the correct procedure to set this up properly ? Apologies if I sound confusing, I hope the attachment helps.Thanks
Wed, May 16, 2012 at 3:32:19 PM | Linked Cad File Help
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't quite understand.  So your Revit project north is different than the AutoCAD project north?  Once you link the file in why not just click on it and rotate it to the orientation that is needed?
Wed, May 16, 2012 at 4:38:10 PM | Linked Cad File Help
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
personally, I'd just rotate the cad, grid intersection to grid intersection, and pin it.
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:15 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:35 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:57 AM
unable to view linked CAD file with pipe
Thu, Apr 18, 2013 at 1:36:28 PM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:51 AM
Page generation time: 19.7048
