41 Users Online (40 Members):
Forums >> Revit Structure >> Technical Support >> position of beam symbolic line on plan
Hi there. I am setting out some steelwork on my plan. The chain dot line that sybolises the beams does not appear to be located on the centre line of the section for PFC's and Angles, I think it is located on the neutral axis of the member. I need to find a way to make the symbolic line appear on the centre line of the member. I have attached a quick note that I wrote with some sketches on to try and explain further.
Thanks for your help
My thought would be to just move the line in the family, however like you I'm not sure what negative effect it would have on the project. If you try moving it please let me know what happens, I am going to take a stab at it now.
I just tried it with a C Channel in a project and it didnt appear to have any negative effect, I could change the lateal justification to Side 1, Side 2, and ACTUAL center with no problems along with changing elevations. If anyone else knows of any problems that could arise I'd like to hear it.
Edited on: Wed, May 16, 2012 at 4:25:25 PM
Vertical bracing symbolic line ??? |
Tue, Jun 4, 2013 at 7:33:50 AM
Symbolic lines |
Tue, Dec 26, 2006 at 2:24:22 AM
Symbolic Lines in Beam Families |
Mon, Feb 24, 2014 at 3:54:58 PM
Beams and Stick Symbols |
Sat, May 9, 2009 at 7:46:06 AM
Symbolic/Model lines bug! |
Wed, Oct 21, 2009 at 1:39:23 AM
Members: | 2070234 | Objects: | 23097 | Forum Posts: | 152262 | Job Listings: | 3 |
