31 Users Online (29 Members):
Forums >> General Discussion >> Revit Project Management >> Site plan
8 Posts No Rating |
Hi,
by default revit shows roof plan in the Site plan view.
Is it possible to show site plan that one line would represent building contour? Also is it possible to cast shadows of all the building if the first floor is selected?
i was trying to make site plan from the fist floor, but since i gave intense topography ground is being cut and i need full topography.
i am using 2013 revit.
Please help.
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
I don't really understand what you are trying to do. I think you are saying that you are trying to have the first floor plan show on the site plan but you cannot change the view range of the site plan to the first floor level becauseit will be cutting through some of your site plan, is that correct? If that is the case you can use a Plan Region to outline your building on the site plan (leaving the view range on the site plan alone) and change the View Range of the Plan Region to cut down to your first floor level.
site plan disappears intermittently |
Thu, Mar 16, 2017 at 9:21:12 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ] |
Tue, Feb 25, 2014 at 4:19:15 PM
26
help!!! deleted site plan! |
Fri, Aug 7, 2015 at 9:23:10 PM
13
Advice on creating a site plan |
Mon, Jul 12, 2010 at 5:04:03 PM
invisible road carparks and landscape on site plan |
Fri, Aug 28, 2009 at 6:44:33 AM
Members: | 2025982 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
