158 Users Online (157 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> True color rendering
Tue, May 15, 2012 at 7:52:12 PM | True color rendering
GLumens
I am rendering the exterior of a building using exterior sun only. I have a wall that I want to be a specific color AFTER the rendering is done. However, the sun is affecting the color during rendering process. Is there a way to adjust the sun so it doesn't change the color of the material but still casts shadows?
Using Revit Architecture 2011.
Wed, May 16, 2012 at 8:08:34 AM | True color rendering
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe you can do what you are looking for.  You will have to do into the Sun Settings when you go to render and do some adjusting and then after your render is complete you can Adjust Exposure to try and get your colors to look the way you want.  It will be a little trial and error.
Rendering color
Tue, Feb 14, 2012 at 10:38:20 AM
Color of lighting after rendering
Wed, Mar 26, 2014 at 8:21:13 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:57 AM
Area Plan Color Scheme Cannot be changed???
Thu, Sep 11, 2014 at 11:58:38 AM
Revit Rendering.
Tue, May 26, 2009 at 9:09:14 AM
Page generation time: 0.6635
