24 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> Altering Revit Structure Wood Beam Families
17 Posts No Rating |
I need to change the wood beam families to show an "X" in the beam when creating a section or elevation. I've been able to do so with the wood column families but not beams. Can anyone provide any information on how to do this? I've tried model lines and symbolic lines and then save the family but the "X" still doesn't show up in my model. I am using Revit Structure 2012. Thank you.
What beam family are you trying to change? I did it with the Structural Framing/Wood/Dimensional Lumber family. I drew in the "X" aligned and locked it to the Reference Planes so that it will stretch with the beam when the size is changed then clicked on the 2 lines that form the "X" and clicked Convert Lines to make them Symbolic lines and brought it into the project with everything working fine.
I'm trying to change all of the wood beam families. I'll try your suggestion. Thank you!
To teafoe5,
What do you mean by drawing the lines "aligned"? What view did you draw your lines in? 3D, Left, or Right?
Thank you.
Revit Structure 2008 SP2: Join Geometry on differnet beam families |
Wed, Sep 19, 2007 at 11:58:38 AM
Built-up wood beams? |
Mon, Apr 3, 2006 at 9:29:26 PM
Detailing a Beam Saddle at Valley Beam |
Wed, Jan 26, 2011 at 12:15:21 PM
Wood frame structure Family |
Sun, Feb 20, 2005 at 7:00:17 PM
REVIT Structure and Architecture for wood framed buildings |
Thu, Apr 18, 2019 at 2:38:02 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
