40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2012 - Try to recover rvt file from Journal Files
Fri, May 11, 2012 at 4:52:34 PM | Revit 2012 - Try to recover rvt file from Journal Files
Canhatelier
Hi everyone...i'm in panic..
My revit crashed, and the last saved rvt file was at 4:20PM, and it crashed at 6:30PM...
The journal file is between 2:00PM and 6:30PM...
Is there a way to recover all the project process that i did between 4:20Pm and 6:30PM with the journal file?
i've tried to move journal file into revit desktop icon, but it only show the process until 4:20PM...and then shows a message: "The journal file could not be run to completion"
Any solution??? Please it´s very important the lost data...
Mon, May 14, 2012 at 8:39:03 AM | Revit 2012 - Try to recover rvt file from Journal Files
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you having trouble finding the journals or they just wont run?  I found this in a previous post.
For 2012 - the HELP says:
Revit Architecture creates a new journal file each time you use the software. The journal file with the highest number is the most recent file. By default, journal files reside in the following location:
  • Windows XP: %USERPROFILE%\Local Settings\Application Data\Autodesk\Revit\<product name and release>\Journals
  • Windows Vista or Windows 7: %LOCALAPPDATA%\Autodesk\Revit\<product name and release>\Journals
The Journal folder is hidden by default in Windows.
Mon, Jun 25, 2012 at 12:16:28 PM | Revit 2012 - Try to recover rvt file from Journal Files
sareh
hi
i found the journal file but it not open with revit.what should i do?
it gives me this message.
please answer me soon. tanx
Journal Files
Wed, Jan 25, 2012 at 3:44:44 PM
.rvt hexa signature-help recovering files from a dead hdd
Mon, Sep 11, 2006 at 5:33:24 PM
Execute Journal File through Batch File
Tue, Jun 14, 2011 at 9:43:15 AM
Rev 2009 Journal Files
Thu, Sep 1, 2011 at 9:04:40 AM
recover unsaved files
Mon, Jul 12, 2010 at 9:52:59 AM
Page generation time: 2.3261
