57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> problem with mullion
Hi
I have Revit Architecture 2012. when i want to use mullion command,
the revit say: "No Curtain Wall Mullions family is loaded in the project, would you like to load on now?"
and i have tried very families to load but no one could be loaded
Is there any body to help me?
57 Posts No Rating |
Hi Pedram,
I have had a similar problem with annotation - tags not loaded even when I tried to. The problem seemed to have more to do with whether they were entities in a referenced Revit file or stuff actually in the file I had open.
Maybe Revit reports that error to you when it's really something else?
think it - build it |
Hi Polar
No I haven`t seen Revit error till now. I think this problem is because of Metric Template that I use in Revit.
The default template in my Revit is Imperial, I can`t work with Imperial unit(foot & inch).
In my country the Metric unit is common. So I have to use Metric template
problem with horizontal mullion |
Mon, Oct 31, 2011 at 2:44:39 PM
Storefront mullion malfunction |
Fri, Feb 10, 2006 at 10:20:55 AM
mullion ang transom not fitting well [ 1 2 ] |
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion |
Thu, Jan 22, 2015 at 4:49:08 PM
mullion join at angled mullion 2017 |
Sat, Oct 21, 2017 at 11:53:54 AM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
