Forums >> Revit Building >> Technical Support >> Tagging items based on view
12 Posts No Rating |
We have a condition where we are tagging cutain wall panels. The problem comes when we checking our mark numbers, dimensions,etc. of the panels by cross referencing our excel reports. The checker must look all over the project to find the curtain panel with that mark number or tag number
Is there a view specific property that I can accees via API or scheduling?
Thank you,
Timothy Livingston
stonepanels.com
To Clarify...
I want to schedule my curtain panels on a specific elevation.
thanks again,
Timothy Livingston
stonepanels.com
Just go to that elevation and TAG your panels as needed.
Based on that response......I really need to clarify.
Can I SCHEDULE based on elevation / view ?
Thank you
So in a schedule you want it to read smoething like... Window Type Elevation Sheet
A WEST A/201
Something like that?
That's it !
Sure you can. Read up on how to create schedules in your help file.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1557-Schedule1557
teafoe5... I would like to see how you schedule a window to show elevation and view without having to enter the data.
Yes you would have to enter the data but you can still make the schedule
Thank you WWHub, you are thinking along the same lines as I am.
Sorry for the "That's It" posts, pointing me to the help file is most definatley not it.
Thank you for all your help
Timothy Livingston
stonepanels.com
The help file would give you information on creating schedules and show you how to manually infill with information that cannot be automatically scheduled. Sorry I did not quite understand you were looking for, good luck.
