30 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Slowing down on particular levels
8 Posts No Rating |
Dear Revit users,
I am working with revit since 08, and there was this little annoying bug - in the middle of working process some levels become super slow - adding walls becomes a big task. At the beginning everything works great, but (I suspect) at some point I add curtain inside the room, something goes wrong and the level becomes slow. It does not help even if I remove curtain walls or purge unused or duplicate window or make separate plan view - if floor area with several basic walls is visible level becomes slow.
Have you experienced the same problem or have any suggestion, please help.
Thank you in advanced.
I don't remember any issue like this... Specs. of your computer please....
8 Posts No Rating |
I have laptop samsung qx510 core i5 2660MHz 560M. 8GB ram, GeForse GT 420M. The strange thing is that is does not slow on other levels, just particular ones, that does not have different information than others.
That's not a >"Super" computer but... did you tried working that file in another computer? Do you have linked CAD files in that view?
Try to "Audit" the file...
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ] |
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels |
Thu, Mar 11, 2010 at 2:38:19 PM
Members: | 2025982 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
