48 Users Online (47 Members):
Forums >> Revit Systems >> Technical Support >> Revit Architecture 2013 Missing Families on Install
1 Posts No Rating |
Hello all,
I am brand new to Revit. I just performed a clean install of Revit Architecture 2013 without changing any options and I can not seem to find any of the families. All I want are the default families that come with the program. The program works great but when I go to say place a door there are no families. I went into the options and checked the default families path which is "ProgamData\Autodesk\RAC 2013\Family Templates\English_I" but there is absolutely nothing located in that folder nor have I been able to located a folder that has anything in it. Any help with getting the program setup properly would be greatly appreciated.
When you go to load a family family (INSERT TAB; LOAD FAMILY) if should bring you to the defailt Revit folders, are you saything that when you do that process there is nothing in the folder?
Under the Revit R pulldown - click on options. Under the file locations tab, places you will see the path set for your libraries. Make sure that is set correctly.
I had this prob. I installed 13 in one computer offline and had the same thing happen. I installed 13 on a diff. computer online and had all the architectural Library and the Mep Library in the defults. When you install online it seem to load the VERY large Library that takes about 45 min depending on dl speed. I then was able to grab the folders and place them in the other computer manually. The content i think is about 500mb big because for revit 13 stuc & mep is included. Hope this helps
Maybe this can help too.... http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19331146&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Sat, Oct 13, 2012 at 11:38:27 AM
1 Posts No Rating |
I also have this problem. I am running the free student version 2013. I had botched install first time by BSoD crash. removed all revit softwares, re-downloaded, installed. found template issuse so i removed and installed 3rd time.
Download Manager keeps stopping itself during Revit 2013 install |
Tue, Sep 24, 2013 at 4:34:52 PM
Missing MEP Library |
Fri, Apr 19, 2013 at 4:10:43 PM
Using tools in the Systems tab - Revit Architecture 2013 |
Wed, Sep 19, 2012 at 4:21:08 PM
Missing Icons in Revit Arch 2013 |
Wed, Jun 5, 2013 at 7:34:40 AM
Missing Revit Library?? |
Mon, Feb 11, 2013 at 9:35:04 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
