51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof soffit inexplicably (to me) showing up as 'beyond'.
Fri, May 4, 2012 at 12:40:54 PM | Roof soffit inexplicably (to me) showing up as 'beyond'.
mikerudolph
Hello,
Rather new to the Revit world and Revit city, and have been able to use the help of this community for almost all my problems but this one...
I have a roof soffit, reveals, and fascia appearing as 'beyond' in one view and not in others.  This particular roof soffit has the same exact type and instance properties as a neighboring roof soffit.  Both are at the same height from the same level.  The linework is set to "by category", and there are no individual element overrides.  There are no plan regions...  I cannot think of any other places to look to find out why this is displaying differently.
This project is in Revit Architecture 2012.
Can anyone offer some insight into why this would be happening?  Thank you in advance.
Fri, May 4, 2012 at 12:43:14 PM | Roof soffit inexplicably (to me) showing up as 'beyond'.
mikerudolph
Sorry attached wrong image...  see below.
Fri, May 4, 2012 at 12:57:49 PM | Roof soffit inexplicably (to me) showing up as 'beyond'.
4 Stars: 203 Votes
Wierd.... In that view did you changed the "Discipline" or a "Phase"?
Fri, May 4, 2012 at 1:01:37 PM | Roof soffit inexplicably (to me) showing up as 'beyond'.
mikerudolph
Nope... Same phase, phase filter, and discipline.
Fri, May 4, 2012 at 3:40:49 PM | Roof soffit inexplicably (to me) showing up as 'beyond'.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
phasing was my first guess.  So just for clarification--the two soffits are definitely in the same phase?
Next step for me would be to copy/paste the correct-looking soffit into the same area as the messed up one and see how visibility holds up.
What about the profile?  Any chance the profile of the soffit was edited so that the base constraint is technically the same, but in reality is higher/lower?
Mon, May 7, 2012 at 11:09:15 AM | Roof soffit inexplicably (to me) showing up as 'beyond'.
mikerudolph
So, I 'figured' it out... kinda.  I have a plan region in another part of the plan, not enclosing any portion of this soffit.  If I adjust the view range of that plan region, or delete all together... the soffit appears correctly.  I am highly confused...  Anyone have an idea why this would happen?
Thanks again.
Soffit that can be scheduled for quantitiesl
Fri, May 26, 2006 at 2:56:31 AM
Roof Fascia Doesnt Render
Fri, Jul 14, 2006 at 5:15:35 PM
Gap in Roof
Tue, Oct 4, 2005 at 1:33:09 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:33 AM
Ceiling Plan View Range
Sat, Feb 23, 2008 at 9:22:54 PM
Page generation time: 1.8215
