110 Users Online (109 Members):
Forums >> Revit Structure >> Technical Support >> Ground beams
7 Posts No Rating |
Can anyone tell me what the best practice for drawing concrete ground beams? i think i could use the wall foundation command, but sometimes you might not have a wall sitting on the beam.
Cheers
Just use a concrete beam and place it at the level you want it.
7 Posts No Rating |
Cheers, i have used the concrete beam, but i am trying to get the ground beam to be part of the 'structural foundation' not 'structural framing'
You could try using a foundation slab then.
Structural Foundation Ground Beams |
Fri, Aug 14, 2009 at 5:58:06 PM
Concrete Beams not extending to Column C/L |
Wed, Jan 28, 2009 at 8:26:37 AM
Ground beams not joing to pile caps (but usually work fine) |
Thu, Feb 18, 2010 at 6:27:45 AM
add beams conceptual mass |
Tue, Oct 15, 2013 at 7:52:39 AM
Rendering Ground Planes showing up when i dont want them to |
Wed, May 10, 2006 at 7:14:43 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
