36 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problem connecting wall sweeps (horizontal and vertical)
Thu, May 3, 2012 at 9:22:38 PM | Problem connecting wall sweeps (horizontal and vertical)
jcuellars
Hi all,
I'm trying to put some sweeps around a door and some windows hosted in walls, after dimensioning the sweeps I join them and got a nice 45ยบ joint, but just in one side. How can I do to work on each side?
Thankyou in advance.
Fri, May 4, 2012 at 5:38:36 AM | Problem connecting wall sweeps (horizontal and vertical)
4 Stars: 203 Votes
Why don't you create that "Sweep" INSIDE the family?
Fri, May 4, 2012 at 12:20:10 PM | Problem connecting wall sweeps (horizontal and vertical)
jcuellars
Thankyou for your quick response, I'm new to Revit, I think I already did that with the same result.
Fri, May 4, 2012 at 12:38:34 PM | Problem connecting wall sweeps (horizontal and vertical)
4 Stars: 203 Votes
You don't understand, Or you create that with an in-place and use that profile with a sweep OR you edit your door and create that sweep INSIDE the family, so, when you load that family you have that profile attached to that door (or windows, that's the same).
Fri, May 4, 2012 at 12:40:55 PM | Problem connecting wall sweeps (horizontal and vertical)
jcuellars
Fri, May 4, 2012 at 12:45:23 PM | Problem connecting wall sweeps (horizontal and vertical)
4 Stars: 203 Votes
An Echo in the "Matrix"?
Fri, May 4, 2012 at 1:12:54 PM | Problem connecting wall sweeps (horizontal and vertical)
jcuellars
I don't know why is repeating my message Sad Sorry about that. And I'm going to try the perfect result you got. Any video or link to study this subject? I'm learning. This is my transition from an experienced Sketchup to a begginer Revit user.
Fri, May 4, 2012 at 1:17:54 PM | Problem connecting wall sweeps (horizontal and vertical)
4 Stars: 203 Votes
Here you have: http://screencast.com/t/S9u4EhYeLB
Fri, May 4, 2012 at 1:20:25 PM | Problem connecting wall sweeps (horizontal and vertical)
jcuellars
Fri, May 4, 2012 at 1:29:39 PM | Problem connecting wall sweeps (horizontal and vertical)
4 Stars: 203 Votes
Definitely is an echo ...
Fri, May 4, 2012 at 1:31:51 PM | Typhoon
#11
jcuellars
Quoting Typhoon from 2012-05-04 13:17:53
Wowww, what a tremendous support from you Typhoon, thankyou very much. Definitely RevitCity will have my donation. I'm a new Revit user and new RevitCity member. Once more thankyou for your help.
Fri, May 4, 2012 at 2:07:27 PM | Problem connecting wall sweeps (horizontal and vertical)
#12
jcuellars
Danation made, Smile. Thx.
Vertical Wall Sweeps
Thu, Sep 13, 2012 at 7:52:25 AM
12
Can you add vertical + horizontal elements in a wall sweep at certain intervals?
Mon, May 25, 2009 at 8:30:22 AM
Trimming sweeps
Wed, Jan 25, 2006 at 3:50:56 PM
Vertical trim ***PLEASE HELP****
Tue, Jun 12, 2012 at 8:05:23 PM
Sloping Wall Sweeps (Revit 2008)
Sat, Jan 26, 2008 at 9:13:09 PM
Page generation time: 1.8917
