110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> linked file elements on host workset...help
Thu, May 3, 2012 at 4:52:20 PM | linked file elements on host workset...help
mshunley
i am collaborating with another firm and have their model linked into mine.  they have setup unique worksets in their file so that i can manage elements.  in all VV settings i can see these worksets and have actually turned off the ones i wanted to.  the problem is that the elements/ worksets are still visible.  when i click on the linked model elements the property dialog box tells me that its on one of my host file worksets.
how do i get their linked file off of my workset and just behave like it should.
this reminds me of acad x-reffing with the wrong layer current, but i thought REVIT didn't do that when you link a file/ model.  i do not see any options for this and it is my understanding that the linked model elements should just be on their correct worksets...not mine.  any help is appreciated.
Fri, May 4, 2012 at 5:46:58 AM | linked file elements on host workset...help
3.5 Stars: 395 Votes
The file behaves correctly and - No - the linked file element is not on your workset but the linked file is.  The linked file's worksets are controlled separately through the VG settings - Revit Links tab.
Turn off the same linked elements in every view [ 1 2 ]
Thu, Nov 29, 2012 at 2:51:08 PM
23
Copying elements from a linked architectural model into my host structural model
Thu, Feb 12, 2015 at 4:30:35 AM
Workset Visibility Issues In Linked File
Wed, May 7, 2008 at 2:19:36 PM
wall joins with a linked file.
Thu, Jan 13, 2011 at 11:51:27 AM
Load workset from Linked file?
Tue, Oct 14, 2008 at 12:11:23 PM
Page generation time: 3.0920
