Forums >> General Discussion >> Revit Project Management >> Revit 2012 VS Revit 2013
![Jamie351 Avatar](user_avatar/249546.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
Hey guys just want your opinions on what you think the Pros and Cons are of the differences.
Revit 2018........ |
here: http://usa.autodesk.com/revit/architectural-design-software/
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00002-New_in_Revit_2013
Edited on: Thu, May 3, 2012 at 6:01:57 AM
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
2013 stairs alone make it leagues ahead of 2012
where is the trim stringers at floor level option???
If you tab at your stair until the stringer is highlighted, you can select each side of the stringer separately, you will get the option in your properties to change the Lower End Cut
does anyone know how to get the structure tap and the others?
I saw on a blog about the new features he had a picture of his User Interface (left) and has extra option highlighted in red.I have put a picture of my user interface on the right to compare.
anyone know how to get these tabs on?
http://screencast.com/t/7GUCOfyAKPSK
I'm assuming he has the suite which has ALL of the disciplines in one Revit program.
I thought Revit 2013 was only 1 program now....
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
there is an option for the Revit one box, i suggest talking to your retailer if you want that version. i like having all the functions
is it still one file to install?
One thing Revit still hasnt fixed not sure if anyone has noticed. On the house sample project there is a window half covered by earth.
Thought they would have made a perfect model as the sample...
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2012 and Revit 2013 simultaneously? |
Thu, Jun 7, 2012 at 12:16:36 PM
Upgrading from revit 2012 to 2013 |
Tue, Apr 23, 2013 at 9:34:40 PM
Upgrading from revit 2010 to 2012 |
Thu, Oct 27, 2011 at 7:19:24 AM
Autodesk Revit 2013 |
Fri, Mar 15, 2013 at 3:17:15 PM
