62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Importing DWG File into Revit
Fri, Dec 23, 2005 at 2:14:26 PM | Importing DWG File into Revit
justinmthomas2003
I found a issue with the texts and dimensions that was added to the view in AutoCAD, before I import the dwg file into Revit. What happens was that the texts/dimenisons got out of place, a little messed up, when I import the dwg file into Revit. I am using Revit 7. Will Revit 8 and 8.1 solve that problem? Hope you guys understands what I am talking about... Thanks,
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:59 PM
error message importing DWG file into Revit
Mon, May 13, 2013 at 11:07:31 AM
Help - Importing 3D Bentley to Revit (.dwg or .dgn to .rvt)
Mon, Jun 2, 2014 at 7:53:21 AM
Importing Sketchup file as dwg
Mon, Oct 28, 2019 at 12:12:19 PM
reducing file size when importing into VIZ 2006
Mon, Apr 3, 2006 at 12:24:34 AM
Page generation time: 4.7715
