55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rouge sections cuts
Wed, May 2, 2012 at 3:35:02 PM | Rouge sections cuts
fstop11
fstop11 Avatar
By this post all that read it will be able to tell that I am new to Revit, so here goes. I am currently working on a flat roof at a local hospital, pretty simple, your typical re-roof job. When I try to use the section cuts for expansion joints, curb details, drains, etc., they all show up on Level 2, I used the Building Section command since there is no "Roof Section" command. How do I keep the section marks confined to the Roof level?
Wed, May 2, 2012 at 3:51:42 PM | Rouge sections cuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Place your sections on the roof level and drag your crop region as desired.  If they are still showing up on unwanted levels, go to that level view, click on the section, right click and select hide component.
Wed, May 2, 2012 at 4:07:32 PM | Rouge sections cuts
fstop11
fstop11 Avatar
That worked perfectly! I guess they left that out in our class.
Thanks
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:02:14 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
How to view sections
Fri, Oct 15, 2010 at 1:48:15 PM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
My section cut symbols don't show on the floor plans
Tue, Jun 20, 2006 at 9:36:27 AM
Page generation time: 1.9815
