29 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface Mount Troffer Light
Wed, May 2, 2012 at 10:56:24 AM | Surface Mount Troffer Light
viorevit
I need to place a troffer light to the ceiling be surface mounted.  I tried to modify the fixture family by moving the ceiling above the fixture, but the fixture still shows recessed mounted in section view.  Please help.  Thanks.
Wed, May 2, 2012 at 11:12:20 AM | Surface Mount Troffer Light
Don't use a troffer, they are recessed.  You can find surface mounted lights in the dowloads.  If you like the troffer "look" - edit the family to move it mbelow the ceiling.
Wed, May 2, 2012 at 11:28:43 AM | Surface Mount Troffer Light
viorevit
Yes, I want to keep the troffer "look".  I couldn't find a surface mount troffer in the Downloads.
I guess my question should be "how can I modify the troffer family?"  I moved the reference level line above the fixture, but that didn't work.
Wed, May 2, 2012 at 12:00:59 PM | Surface Mount Troffer Light
Remember, I said don't use a trofferYou would be better off to use a surface mtd flourescent and add the box.  Much simpler.
Wed, May 2, 2012 at 12:08:55 PM | Surface Mount Troffer Light
viorevit
Sorry, I though you meant to modify the Troffer.  I'll try your suggestion.
Thank you so much for you help!
Mon, Jun 2, 2014 at 3:52:38 PM | Surface Mount Troffer Light
Andy100101
My problem is on the opposite
I used revit drywall ceiling and recessed light. But the light always sit on the surface of the ceiling rather than cut and sit flash to the ceiling surface.
Thanks!!
Tue, Jun 3, 2014 at 7:19:52 AM | Surface Mount Troffer Light
If your light doesn't recess, then its not a recessed light no matter what it is called.  Find a different fixture.
light troffer
Mon, Nov 17, 2008 at 1:40:47 PM
Light Troffer
Tue, Feb 16, 2010 at 12:11:28 PM
T-BAR WITH TROFFER LIGHT
Mon, Mar 24, 2008 at 12:22:52 PM
Light not placed on the surface of one wall but is on the surface of another?!?
Mon, Sep 17, 2012 at 7:26:20 AM
light fixture graphics
Mon, May 14, 2012 at 11:25:01 AM
Page generation time: 0.8167
