68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Bar Bending Schedules Using Revit Structure 2012
Wed, May 2, 2012 at 5:17:11 AM | Bar Bending Schedules Using Revit Structure 2012
Mastan
Hi All, I would like to know if it is possible to get bar bending schedule in revit structure 2012 for the elements like slabs with varying slab edges & openings, walls, columns, foundations.etc. please respond ASAP.
Thank You...
Wed, May 9, 2012 at 11:15:54 AM | Bar Bending Schedules Using Revit Structure 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes you can pretty much make any type of schedule you want.  Check out the schedule section in your help.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1557-Schedule1557
structure analys with Revit
Thu, May 11, 2006 at 1:01:40 PM
Cursor not visible in schedules, Revit Structure 2014
Tue, Apr 29, 2014 at 2:16:16 PM
exporting point info from revit structure into a text file
Tue, Jul 24, 2012 at 12:20:45 PM
Can't find precast concrete wall tees in Revit Structure 2012
Thu, Mar 15, 2012 at 9:53:48 AM
ReBar Schedule
Thu, Jul 11, 2013 at 4:02:01 AM
Page generation time: 3.9463
