32 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Massing Studies with Multiple Buildings with different levels
Fri, Apr 27, 2012 at 3:37:44 AM | Massing Studies with Multiple Buildings with different levels
BGT77
I would like to know the best workflow to create a massing study for a large plot of land with many buildings (30 buildings). I would like to assign different levels for each building type as some are residential, others office and others retail etc - Therefore the floor to floor heights are all different. I would like to generate an area schedule, change the masses and see the areas change.
I understand how to do this with one mass, or multiple masses using the Mass Floors command with the same levels assigned to all masses (Project Levels). Surely I dont have to put all the different masses into separate Revit files at this early stage of the project?
Many thanks for any help.
Ben
Fri, Apr 27, 2012 at 11:06:36 AM | Massing Studies with Multiple Buildings with different levels
mdvandenakker
I think others could speak better to this, but you may consider using Autodesk's Vasari for that. It is meant for the quick massing studies that will go into revit, and it is free for a while.
http://labs.autodesk.com/utilities/vasari/
mv
Sat, Apr 28, 2012 at 2:32:46 AM | Massing Studies with Multiple Buildings with different levels
BGT77
Thanks for your reply.
I'll have a look into that, but I would prefer to know how to do this in Revit as i think it's a common starting point of all our large scale urban design projects. To boil down the question to a basic level, is it possible to assign specific levels to a conceptual mass, as one mass may be a hospital, another a school - with different levels.
Cheers,
Ben
Daylight Studies of Massing Models
Thu, May 27, 2004 at 8:18:12 PM
Multiple buildings on one site
Wed, Feb 4, 2009 at 6:52:05 PM
Multiple Levels..Many Multiple levels..
Fri, Jan 21, 2005 at 7:06:27 PM
Multiple Buildings - 1 Drawing Set
Wed, Jun 4, 2008 at 1:46:06 PM
Documenting Multiple buildings
Thu, Feb 7, 2008 at 3:19:49 PM
Page generation time: 0.4455
